Hi everyone,
I was just wondering if anyone else’s shadow option in rendered mode or in view capture setting not working since latest update? Despite having the options on in display mode… Anyone?
Thanks!
Hi Tania -
I haven’t seen other reports of that, no.
Thanks, Wim. Can you possibly help pinpoint what might be the problem? I have the “shadows on” in display mode options, and also the GPU box ticked in the OpenGL settings… It just stopped working.
Any ideas?
Thanks again.
Hi Tania -
Please start by running the Rhino SystemInfo command and copy-paste the result here.
Thank you!! Here goes:
Rhino 7 SR28 2023-2-27 (Rhino 7, 7.28.23058.03002, Git hash:master @ 4ffc5d7156fbccf2a5d9fcc80e522b3851bc7f6c)
License type: Educational, build 2023-02-27
License details: Stand-Alone
Apple macOS Version 13.2.1 (Build 22D68) (Physical RAM: 40Gb)
Mac Model Identifier: iMac19,1
Language: en-ES (MacOS default)
AMD Radeon Pro 570X OpenGL Engine (OpenGL ver:4.1 ATI-4.9.51)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 4 GB
Graphics: Radeon Pro 570X
Displays: iMac (217dpi 2x)
Graphics processors
Radeon Pro 570X (4 GB)
iMac (2560 x 1440)
USB devices
Apple Inc.: FaceTime HD Camera (Built-in)
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/usr/lib/usd/libIex.dylib
/usr/lib/usd/libHalf.dylib
/usr/lib/usd/libAlembic.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/usd/libosdCPU.dylib
/usr/lib/usd/libImath.dylib
/usr/lib/usd/libIlmThread.dylib
/usr/lib/usd/libIexMath.dylib
/usr/lib/usd/libtbb.dylib
/usr/lib/usd/libMaterialXCore.dylib
/usr/lib/usd/libMaterialXFormat.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftExtensionFoundation.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftExtensionKit.dylib
/usr/lib/swift/libswiftWebKit.dylib
/Users/Tania/Library/Application Support/McNeel/Rhinoceros/packages/7.0/SubstanceImporter/2.0.3/libSubstanceImporter.dylib
/Users/Tania/Library/Application Support/McNeel/Rhinoceros/packages/7.0/SubstanceImporter/2.0.3/libsubstance_ogl3_blend.1.dylib
/Users/Tania/Library/Application Support/McNeel/Rhinoceros/packages/7.0/SubstanceImporter/2.0.3/libsubstance_linker.1.dylib
/Users/Tania/Library/Application Support/McNeel/Rhinoceros/packages/7.0/SubstanceImporter/2.0.3/SubstanceImporter.rhp “SubstanceImporter” 2.0.3.0
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.28.23058.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.28.23058.1002
/Applications/Rhino 7.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 7.28.23058.1002
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.28.23058.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.28.23058.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.28.23058.3002
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.28.23058.1002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.28.23058.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.28.23058.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.28.23058.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.28.23058.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.28.23058.3002
Thanks, Tania -
You’re running a 2019 iMAC with an AMD on the latest - and very recent - version of macOS. Generally, that would be the best. Lately, though, Apple hasn’t necessarily cared much for OpenGL support in macOS, so that could be in play here.
Have you tried unticking that to see if that makes a difference? Also lowering the antialiasing to none to see if that helps?
If that doesn’t do anything, please post a simple 3dm file that we can check on our machines.
Wim, lowering the antialiasing to none, worked. Arghhh thank you!!
