“Shadows ignore user defined clipping planes” doesn’t work in the current Rhino 8 WIP. Can anyone confirm if there is a bug?
It still doesn’t work in the Rhino 8.1.
Likely it is a bug
Yes, and it’s a regression. I just checked the new release candidate, it’s still here. I think regressions should have a priority in being fixed.
It will be solved. Moving targets here being tackled by the team.
@stevebaer can you look into this one?
Hi -
That’s a bug, yes. I’ve put this on the list as RH-78193 Display: Shadows to ignore clipping planes
Please, can you give this regression some priority on Windows? It still doesn’t work in 8.6.24074. Very soon I will need this functionality and this is broken since at least October. ![]()
It was reported before Rhino 8 went out of beta… (October 18 / October 31)
Hi Barden -
RH-78193 was fixed on November 9th.
If you are running into something with 8.6, I’ll need detail to try to reproduce that here.
I can reproduce this also and actually, I also need this working.
shadow clipping plane.3dm (227.6 KB)
System Info
Rhino 8 SR6 2024-3-14 (Rhino 8, 8.6.24074.01001, Git hash:master @ def4e7ae5a5339578727a42cbd95e31d75b3faf0)
License type: Commercial, build 2024-03-14
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 64GB)
.NET 7.0.11
Computer platform: LAPTOP - Plugged in [95% battery remaining]
Primary display and OpenGL: NVIDIA RTX A3000 12GB Laptop GPU (NVidia) Memory: 11GB, Driver date: 2-15-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.61
Primary OpenGL: NVIDIA RTX A3000 12GB Laptop GPU (NVidia) Memory: 11GB, Driver date: 2-15-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.61
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 6-15-2023 (M-D-Y).
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 2-15-2024
Driver Version: 31.0.15.5161
Z-Buffer depth: 24 bits
Total Video Memory: 11520 MB
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 5.3.2.0
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\Bella (813de3fb-18eb-405f-bfcd-b0b4d3da91fb)\24.2.0.0\bella_rhino.rhp “Bella” 24.2.0.0
C:\Users\Czaja\Desktop\Rhino_7_Win_2023.0417\HDRLightStudioTexture.rhp “HDRLightStudioTexture”
C:\Program Files\Common Files\McNeel\Rhinoceros\8.0\Plug-ins\Crayon (39629248-4fa6-47b8-83c7-745a7efea259)\1.2.0.0\Crayon\Crayon.rhp “Crayon” 1.0.0.0
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\BlockEditNew\BlockEditNew.rhp “BlockEdit” 1.0.0.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.6.24074.1001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.6.24074.1001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.6.24074.1001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.6.24074.1001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.6.24074.1001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.6.24074.1001
Rendered view
Rendered with disabled clipping plane
Rendered settings
Raytraced (expected results)
Thanks, that’s exactly it. I have the same results with your file.
Can some another user with Rhino 8.5 or 8.6.24074 check if “Shadows ignore user defined clipping planes” works, please? I would really appreciate knowing if it’s really broken again.
If it’s not working, please reopen the YouTrack issue.
I can confirm that it doesn’t work here either ![]()
Hi, Can you please check this file or just put 1 box and 1 clipping plane in the Rhino?
All you need to do is to set “Shadows ignore user defined clipping planes” ON in the Rendered mode and set some light to check whether shadow is made by clipped geometry or full object.
It’s important and if it doesn’t work for you as for the other users, please reopen the YouTrack item.
@jeff
This does look broken for the Rendered display mode…I’ll take a look.
I do want to point out here though, that this is not going to work for Raytraced display modes…and it currently will not work in Mac Rhino’s Rendered mode…until I can get to it.
Thanks,
-Jeff
Thank you! Fortunatelly, I’m using Windows and do not render in Rhino. Rendered mode is all I need to just look how sun rays behave. I hope it can be fixed soon, because I can’t afford going with my work back to Rhino 7…
It appears that this was broken in 8.5… so at the very worst case, you could roll back to 8.4…
-J
This will be fixed in the 8.6 Service Release (SR6).
Thanks,
-Jeff
Hey Jeff,
Is there news on when it will be fixed for MacOs? I would love to use it for my next project but on Version 8.12 it still doesnt work for me…
Hi Paul -
The macOS part of this issue is on the list as RH-78308 Display: Shadows to ignore clipping planes
This is currently on the 8.x list…
RH-78308 is fixed in Rhino 8 Service Release 14
Rhino 8.14.24317 Windows
Many things are wrong when we set the Rendered view with Clipping Plane and Shadows ignore user defined clipping planes = yes.
I discussed this feature in the context of Visual ARQ in another thread and noticed this BUG in the latest version of Rhino 8. Generally, Shadows ignore user defined clipping planes problems appear and disappear every few versions, I hope that one day they will be able to be banished forever.
Rhino Clipping Planes Problems.3dm (255.5 KB)
System Info
Rhino 8 SR14 2024-11-12 (Rhino 8, 8.14.24317.14001, Git hash:master @ 69ab12ed53cf1e6d17f23ab5fec3c3f7216df72d)
License type: Educational, build 2024-11-12
.NET 7.0.11
Primary display and OpenGL: NVIDIA RTX A3000 12GB Laptop GPU (NVidia) Memory: 11GB, Driver date: 6-10-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 538.78
Primary OpenGL: NVIDIA RTX A3000 12GB Laptop GPU (NVidia) Memory: 11GB, Driver date: 6-10-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 538.78
Intel(R) UHD Graphics (Intel) Memory: 128MB, Driver date: 4-2-2024 (M-D-Y).
OpenGL Settings
Safe mode: Off
GPU Tessellation is: Off
Anti-alias mode: 8x
Render version: 4.6
Driver Date: 6-10-2024
Driver Version: 31.0.15.3878
C:\Program Files\Rhino 8\Plug-ins\RhinoToGrasshopper\RhinoToGrasshopper.rhp “RhinoToGrasshopper” 1.0.0.0
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Synapse\0.4.0\SynapseRCP.rhp “SynapseRCP” 0.4.0.0
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Crash\1.4.2-beta\Crash.rhp “Crash” 1.4.0.0
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\Crayon (39629248-4fa6-47b8-83c7-745a7efea259)\1.2.0.0\Crayon\Crayon.rhp “Crayon” 1.0.0.0
C:\Users\Czaja\source\repos\EtoDockableApp\EtoDockableApp\bin\Debug\net48\EtoDockableApp.rhp “EtoDockableApp” 1.0.0.0
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\SubstanceImporter\2.0.7\Substance.Win.rhp “SubstanceImporter” 2.0.7.0
C:\Program Files\Rhino 8\Plug-ins\Karamba\License\Karamba3D_LicensePlugin_Rhino8.rhp “Karamba3DLicense”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.14.24317.14001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.14.24317.14001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.14.24317.14001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.14.24317.14001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.14.24317.14001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.14.24317.14001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.14.24317.14001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.14.24317.14001
Visual ARQ Level Cut Plane
