I am using rendered viewport with shadows turned on, utilizing sun for light, and the shadows incorrectly appear offset from objects. This is a viewport issue, not result of render command. Any idea why shadows do not connect to the objects casting them?
Hi Matt - can you post the vertical objects and the plane they are sitting on?
thanks,
Yes - sure.
Added additional geometry to further show the problem. Notice also that the person as single surface also does not cast shadow at all.Rhino 5 shadow error model.3dm (1.3 MB)
Hi Matt - you can make this somewhat better by, in the rendered mode settings in Options > View >Displaymodes:
- Slide the Video memory slider to the right, to taste.
- Slide ‘Self shadowing Artifacts’ to the left.
- Shrinking the camera based clipping bubble. (Slide to the left)
Actually, I just discovered that sliding the camera based clipping bubble slightly over to the right from ‘none’, but not too far, mostly fixed the problem.
Matt
Yeah, that’s it - I should have said, slide that one left but not all the way to the left, which turns it off.
Pascal,
This shadow problem is recurring (offset shadows in rendered viewport) and the clipping bubble is no longer helping (and when I use it, the whole image is not shadowed, only a portion). I can find no solution to this weird displacement of shadows. Also notice in this image the jagged shadow edge. Is this just a limit of this viewport shadow functionality? It seems odd.
Thanks,
Matthew
Hi Matthew - is the scene very large? If you hide parts that are distant from the current view, does it change the shadowing?
Pascal -
No, this is a smallish model, with only the building and some adjacent ground plane objects (but nothing distant, not high polygon count, etc.).
Matthew
Hi Matthew - just as a test - hide the ground planes… any different?
Hi Matt - is this new V5 behavior or has it always been like this? What video card are you using, can you post an image of your Options > View > openGL page? Does noodling with the ‘Soft edge quality’ slider do anything for the jaggies?
Hi Matt - I see the driver is more than a year old - I don’t say it will fix it, but you might want to update that. Messing with your model some more, I can clean things up quite a bit with the clipping bubble and edge quality slider. The bubble needs to be just large enough to allow shadows into the visible part of the scene - remember all the way left shuts it off completely- you need to slide it off the stop on the left side.
Hi Mathew, Hi Pascal!
I had the exact same problem and it was driving me completely crazy!
I think it really must have to do with the camera clipping bubble(–whatever that is–). too small objects just didn’t cast any shadow at all!!!
since my model is quite large (landscape) i figured i could be i am too far away of the origin(since i use absolute pos values) i figured that might cause the problem…
so i finally decided to move my model to the origin 0,0,0
and: everything just works perfect!!! hope this is some help to you, martin
Hi - could you post a 3dm file that shows this behavior? Also, please run the Rhino SystemInfo command and post the result here.
Hi Wim!
I include parts of my file—since all of it would be too big
The Problem remains the same…. (i also include a screenshot of what i mean…)
Thanks, martin
Systeminfo:
Rhino 6 SR19 2019-10-22 (Rhino 6, 6.19.19295.01001, Git hash:master @ 0af62045bd35259d4c2367dbf7f9ef94ded29299)
License type: Educational, build 2019-10-22
License details: Stand-Alone
Windows 10.0 SR0.0 or greater (Physical RAM: 12Gb)
Machine name: I5
Non-hybrid graphics.
Primary display and OpenGL: NVIDIA GeForce GTX 750 (NVidia) Memory: 2GB, Driver date: 10-27-2017 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 388.13
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-27-2017
Driver Version: 23.21.13.8813
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.19.19295.1001
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.19.19295.1001
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.19.19295.1001
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.19.19295.1001
I solved this problem by moving my geometry closer to the World Origin.
Did anyone else uncover a similar solution?
