I am quite new to Rhino so I am sorry if that’s an easy fix problem but why does this look so distorted?
Also why these shadows are so imprecise?
Thanks,
Daniel
Hi Daniel - try setting the camera bubble - does that help?
Hi - Apart from what Pascal said, perhaps you model is very far away from the origin?
The camera bubble didn’t do anything, I have also checked it in the world’s centre and with all plugins disabled (both issues). The render view issue just disappeared which is cool but what if it happens again…
The shadows are still imprecise here and there. Mostly it’s alright but it’s not revit/sketchup quality.
Daniel
Hi Daniel -
Is the part that you showed just a bit of a much larger scene? If so, then that’s a known issue.
If you post the file, we could take a closer look…
