Hi i am testing my new Mac work environment.
New mac, newest OSX (12.1) and newest Rhino 7 Version 7.13.213…
When i open some files that are NOT Damaged (i tested it with WIP 8 and Rhino 7 on Intel Macs) i get some fancy looking surfaces appearing by moving the perspektive view. By rotating the view, these surfaces disappear and some others appear. ist really like disco lights.
There is no reason for these surfaces, as my geometry is clean!!
Same problem here
Helps when I delete any meshes in the model.
Rhino 7 is sluggish in rendered for me with a larger model (m1max 32gb) rhino 8 a little better. Testmetal super fast although global illumination not quite there so in rendered looks like rhino 5 as standard. Hoping more updates solves in time. Also experiencing some clipping plane problems in WIP R8
Make sure you’re up to date and getting the weekly releases if you are experiencing this display issue. There will be a follow up on this thread as well. Thanks.
As Japhy wrote, there will be a follow-up on this thread. We have the issue on the list as RH-66818 (which is not visible to the public) and this thread is referenced. When the issue gets resolved, this thread will be notified.
