Rhino7 display issues
Rhino 7.15.22039.13002
Geometry attached.
geom.step (40.4 KB)
Image of display issue.
displays well here, will you open rhino and run the systeminfo command, then post the results?
No display problems here on my older medium resource system either.
If you do a ZEA (Zoom Extents All viewports), does that sort the display?
Failed to mention this issue is on a mac laptop.
Model Name: MacBook Pro
Model Identifier: MacBookPro16,1
Processor Name: 8-Core Intel Core i9
Processor Speed: 2.3 GHz
Number of Processors: 1
Total Number of Cores: 8
L2 Cache (per Core): 256 KB
L3 Cache: 16 MB
Hyper-Threading Technology: Enabled
Memory: 16 GB
Boot ROM Version: 1037.100.359.0.0 (iBridge: 17.16.14263.0.0,0)
Activation Lock Status: Disabled
AMD Radeon Pro 5500M:
Chipset Model: AMD Radeon Pro 5500M
Type: GPU
Bus: PCIe
PCIe Lane Width: x8
VRAM (Total): 4 GB
Vendor: AMD (0x1002)
Device ID: 0x7340
Revision ID: 0x0040
ROM Revision: 113-D3220E-190
VBIOS Version: 113-D32206U1-019
Option ROM Version: 113-D32206U1-019
EFI Driver Version: 01.01.190
Automatic Graphics Switching: Supported
gMux Version: 5.0.0
Metal: Supported, feature set macOS GPUFamily2 v1
Displays:
Color LCD:
Display Type: Built-In Retina LCD
Resolution: 3072 x 1920 Retina
Framebuffer Depth: 24-Bit Color (ARGB8888)
Main Display: Yes
Mirror: Off
Online: Yes
Automatically Adjust Brightness: No
Connection Type: Internal
Hi Greg - please run the Rhino SystemInfo command and copy-paste the result here.
Rhino SystemInfo gives:
Rhino 7 SR15 2022-2-8 (Rhino 7, 7.15.22039.13002, Git hash:master @ 2833e18992fc4b5cf99bb29c4d8e8add4f02074d)
License type: Educational, build 2022-02-08
License details: Cloud Zoo
Apple macOS Version 10.15.4 (Build 19E266) (Physical RAM: 16Gb)
Mac Model Identifier: MacBookPro16,1
Language: en-US (MacOS default)
AMD Radeon Pro 5500M OpenGL Engine (OpenGL ver:4.1 ATI-3.8.24)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 4080 MB
Graphics: AMD Radeon Pro 5500M
Displays: Color LCD (264dpi 2x)
Graphics processors
Intel UHD Graphics 630 (1536 MB)
AMD Radeon Pro 5500M (4 GB)
Color LCD (1792 x 1120 @ 59 Hz)
USB devices
GenesysLogic: USB3.1 Hub
Realtek: USB 10/100/1000 LAN
PixA琀: USB Optical Mouse
PNY: USB 2.0 FD
Western Digital: easystore 25FC
Apple: composite_device
Apple Inc.: Touch Bar Backlight
Apple Inc.: Touch Bar Display
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple: Headset
Apple Inc.: Ambient Light Sensor
Apple Inc.: FaceTime HD Camera (Built-in)
Apple Inc.: Apple T2 Controller
Bluetooth devices
None
Third party kernel extensions
org.virtualbox.kext.VBoxDrv (6.1.32) 2966CECD-ED9D-33B1-9B19-35D5B2F3C2A3
org.virtualbox.kext.VBoxUSB (6.1.32) 2A227B02-53F7-3AC9-8633-3DA6BC2C99F6
org.virtualbox.kext.VBoxNetFlt (6.1.32) FCFA4205-F86E-3847-87F9-FD20D97978B2
org.virtualbox.kext.VBoxNetAdp (6.1.32) 596D7961-E512-363D-B8C0-12F4B22D8678
Third party plugins
/usr/lib/swift/libswiftFoundation.dylib
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 7.15.22039.13002
/Applications/Rhino 7.app/Contents/PlugIns/Import_WAMIT.rhp “WAMIT import” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 7.15.22039.13002
/Applications/Rhino 7.app/Contents/PlugIns/export_3MF.rhp “export_3MF” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.15.22039.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 7.15.22039.13002
/Applications/Rhino 7.app/Contents/PlugIns/Import_X.rhp “X Import” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoBonusTools.rhp “Rhino Bonus Tools” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_PLY.rhp “PLY - Polygon File Format Import” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_UDO.rhp “Moray Export” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 7.15.22039.13002
/Applications/Rhino 7.app/Contents/PlugIns/Export_CSV.rhp “Comma Separated Value Export” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_WAMIT.rhp “WAMIT Export” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/Import_OFF.rhp “OFF Import” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/Import_SolidWorks.rhp “Solidworks Import” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_ACAD.rhp “AutoCAD file export : export_ACAD” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_CD.rhp “Cult3D Export” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_SLC.rhp “SLC Export” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 7.15.22039.13002
/Applications/Rhino 7.app/Contents/PlugIns/export_STL.rhp “STL Export” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/NamedPositions.rhp “Named Position” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/SolidTools.rhp “SolidTools” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_RAW.rhp “RAW Triangle Import” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_XGL.rhp “XGL Export” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_LWO.rhp “Lightwave Export” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_PDF.rhp “PDFReader” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_STEP.rhp “STEP Import” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_AI.rhp “Adobe Illustrator Export” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_VRML.rhp “VRML/X3D Export” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/Squish.rhp “Squish” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.15.22039.13002
/Applications/Rhino 7.app/Contents/PlugIns/CreaseAngle.rhp “CreaseAngle” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.15.22039.13002
/Applications/Rhino 7.app/Contents/PlugIns/import_Points.rhp “Points Import” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.15.22039.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 7.15.22039.13002
/Applications/Rhino 7.app/Contents/PlugIns/export_SKP.rhp “SketchUp Export” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_VRML.rhp “VRML Import” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_Points.rhp “Points Export” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 7.15.22039.13002
/Applications/Rhino 7.app/Contents/PlugIns/Export_RAW.rhp “Raw Triangles Export” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_VDA.rhp “VDA Import” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_GTS.rhp “GTS Export” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 7.15.22039.13002
/Applications/Rhino 7.app/Contents/PlugIns/Import_SLC.rhp “SLC Import” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoLabsTools.rhp “Rhino Labs Tools” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_SAT.rhp “ACIS Export” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/Import_DGN.rhp “MicroStation file import: import_DGN” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_STEP.rhp “STEP Export” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.15.22039.13002
/Applications/Rhino 7.app/Contents/PlugIns/MeshFromPoints.rhp “MeshFromPoints” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_POV.rhp “POV-Ray Export” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_3MF.rhp “import_3MF” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_FBX.rhp “Export_FBX” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/MPlane.rhp “MPlane” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_3DS.rhp “3D Studio Export” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_VDA.rhp “VDA Export” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 7.15.22039.13002
/Applications/Rhino 7.app/Contents/PlugIns/Import_M.rhp “Import_M” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/Import_GTS.rhp “GTS Triangle Import” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_SKP.rhp “SketchUp Import” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_FBX.rhp “Import_FBX” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/MeshTools.rhp “MeshTools” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_ACAD.rhp “AutoCAD file import: import_ACAD” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_STL.rhp “STL Import” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_RIB.rhp “Renderman Export” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_X.rhp “X Export” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 7.15.22039.13002
/Applications/Rhino 7.app/Contents/PlugIns/import_LWO.rhp “Lightwave Import” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 7.15.22039.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 7.15.22039.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.15.22039.13002
/Applications/Rhino 7.app/Contents/PlugIns/Export_X_T.rhp “Parasolid Export” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 7.15.22039.13002
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 7.15.22039.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_IGES.rhp “IGES Import Plug-in” 7.15.22039.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 7.15.22039.13002
John, I was trying to replicate the display issue this morning, and all looks great now. I am glad that I snapped a photo of the previous issue to prove I am not delusional. If the issue reoccurs, I will add to this post. It appears to have been a unique combination of system state that has now changed???
No one ever thought you were delusional.
Apple does a pretty poor job of keeping their display drivers tuned up.
I suspect you will see this again.
Rhino is the symptom, not the likely cause.
Hopefully you’ll figure out a specific command pattern that is likely to cause the issue. With those details, maybe we can write a work-around.
Thanks
Hey Greg fwiw you are on OSX Catalina 10.15.4
our system requirements are for the 10.15.7 build of Catalina. May be worth grabbing that small update and see if rhino doesn’t settle down.
I upgraded my OSX to 10.15.7, and Rhino graphics was great up until a few minutes ago.
Porcupine needles suddenly started appearing in all files after I read in a new SLDPRT file.
Any suggestions, friends?
Can you run SystemInfo in Rhino and copy paste the results here?
That info was pasted in a previous post in this thread.
A machine reboot has cleared the issue (…for now).
Thanks
Hey Greg, pulling a thread here…
any chance you ran SelBad to see if the imported model itself has bad geometry?
SW has some notorious habits for creating bad surfaces, especially when you data transfer to a surfacing package like rhino or alias.
I didn’t, Kyle. I didn’t even know that command existed.
I did save the porcupine geometry as a .3dm, and it imported fine after the reboot.
BTW, I have watched several of your excellent tutorials. You helped me tremendously with the new SubD functionality.
Go to OpenGL settings in Rhino and turn off GPU Tessellation.
Thanks, Steve. I will try that if the issue later reappears.
Actually, the GPU Tessellation was already off.
Is there any chance you can update to a more modern version of macOS? 10.5 is pretty old
I’ve got the model with the last Intel chip before the move to the M1. So, I am kind of screwed OS-wise (I think).
Not really.
You’re on 10.15.4
Here’s the list from System Requirements:
I’m running the same system:
2019 MBP 16,1 with the AMD 5500M
macOS Ventura 13.4
It’s a FAR BETTER system for Rhino 7 than the Silicon Macs.
