Surface color always grey
I have a problem with my surface appearance in Rhino in shaded mode. They always display in dark grey even if I change the color in the properties.
Thanks for your input on this.
Hello - try resetting the Shaded mode to defaults in Options > View > Display modes.
Thanks for your very quick reply. I tried doing this but I still have the same problem
Hello- Please run the SystemInfo command in Rhino and copy/paste the results here.
Rhino 7 SR2 2021-1-21 (Rhino 7, 7.2.21021.07001, Git hash:master @ 96ff97351fbdf5d2acdeaf781aea1577f2ff60f7)
License type: Pack école Revente interdite, version 2021-01-21
License details: Cloud Zoo
Windows 10.0.19041 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: LAPTOP - Plugged in [89% battery remaining]
Primary display and OpenGL: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 12-23-2020 (M-D-Y). OpenGL Ver: 1.1.0
Secondary graphics devices.
NVIDIA GeForce GTX 1650 (NVidia) Memory: 4GB, Driver date: 1-8-2021 (M-D-Y).
> Integrated acclerated graphics device (shares primary device ports)
- This device is not being used
ATTENTION:
No graphics device is being used. Either an error occurred on startup, or certain devices have been disabled.
See below for any possible configuration changes that may help resolve this issue.
  • Any hardware configuration or cabling changes you make will require that you restart Rhino.
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Microsoft Corporation
Render version: 0.0
Shading Language: Non pris en charge
Driver Date: 12-23-2020
Driver Version: 27.20.100.9126
Maximum Texture size: 1024 x 1024
Z-Buffer depth: 32 bits
Total Video Memory: 1 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.2.21021.7001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.2.21021.7001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.2.21021.7001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.2.21021.7001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.2.21021.7001
Hello - I would do a clean uninstall and reinstall of the graphics drivers - both - getting the latest drivers from the nVidia and Intel websites.
Next, update Rhino to the latest, which will be 7.5 later today.
I’m having the same issue here. When i’m in shaded viewport everything gets displayed properly. But once i drag the view around, all the sufraces are grey and only the edges are diplayed in the according layer color. This happens in all views, not only in perspective. Resetting the viewport-settings didn’t change anything.
I’m using the latest rhino 7 SR update ( 7.26.23009.07001) and the latest Nvidia Studio drivers on Win11, more detailed info listed below.
Is there anything else i can try except updating rhino and graphics drivers and resetting the viewport settings to standard?
Rhino 7 SR26 2023-1-9 (Rhino 7, 7.26.23009.07001, Git hash:master @ 92abcf7c453c78a236526390d91d0ac1f6779143)
License type: Studentenlizenz, Build 2023-01-09
Windows 11 (10.0.22000 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3060 (NVidia) Memory: 12GB, Driver date: 12-22-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 528.02
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 2.1
Anti-alias mode: 8x
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-22-2022
Driver Version: 31.0.15.2802
Z-Buffer depth: 24 bits
Total Video Memory: 12 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.26.23009.7001
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.26.23009.7001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.26.23009.7001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.26.23009.7001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.26.23009.7001
Hi Julius -
It looks like the Rhino Options -> View -> OpenGL -> Level slider has been moved to the middle of that control. With your GPU, you should be able to run Rhino with that one set to the right end.
That did the trick, thanks for the quick help!!!
i am also facing a similar issue…not sure what to do. All surfaces are appearing gray with only the edges showing respective color, in default display settings in Rhino 8
Computer platform: LAPTOP - Plugged in [99% battery remaining]
NVIDIA GeForce RTX 3050 Ti Laptop GPU (NVidia) Memory: 4GB, Driver date: 11-11-2024 (M-D-Y).
> Integrated accelerated graphics device (shares primary device ports)
AMD Radeon™ Graphics (AMD) Memory: 1GB, Driver date: 5-30-2023 (M-D-Y).
ATTENTION:
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Graphics level being used: OpenGL 0.0 (primary GPU’s maximum)
Anti-alias mode: None
Render version: 0.0
Shading Language: Not supported
Driver Date: NA
Driver Version: NA
Total Video Memory: 64 MB
C:\Program Files\Enscape\Enscape.Rhino.Plugin-net48\Enscape.Rhino8.Plugin.dll “Enscape.Rhino8.Plugin” 4.1.0.1388
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.16.25042.13001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.16.25042.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.16.25042.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.16.25042.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.16.25042.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.16.25042.13001
Something is wrong with your video card installation. Suggest you download the latest driver from NVidia and do a clean install to see if that fixes it. Probably also update the AMD driver.
Hi, i tried downloading latest driver from NVidia and did a clean reinstall. However that did not fix the issue.
Hi -
Please post the new (and complete!) output from the SystemInfo command.
Hi, My AMD driver was disabled in the device manager. Enabling that helped fix the issue. Thanks.
Hello, I am having the same issue. But I am running on a terminal server, windows 2019 standard.
Results from SystemInfo command.
Rhino 8 SR14 2024-12-10 (Rhino 8, 8.14.24345.15001, Git hash:master @ cdb74b46090a23fe242c51b288886f76467a741b)
License type: Commercial, build 2024-12-10
Windows 10 (10.0.17763 SR0.0) (Server) or greater (Physical RAM: 64GB)
.NET Framework 4.8.4795.0
NVIDIA GeForce RTX 3050 (NVidia) Memory: 6GB, Driver date: 8-14-2024 (M-D-Y).
> Accelerated graphics device with 0 adapter port(s)
- There are no monitors attached to this device!
Intel(R) UHD Graphics 770 (Intel) Memory: 2GB, Driver date: 6-21-2025 (M-D-Y).
> Integrated graphics device with 0 adapter port(s)
ATTENTION:
Desktop is using the slower, less reliable integrated graphics device and probably needs a configuration change.
There is only one monitor detected, but it’s connected to the slower, integrated graphics video port.
  • Recommended: Unplug the monitor and plug it into one of the video ports on this device:
    [NVIDIA GeForce RTX 3050]
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 0.0
Driver Date: 8-14-2024
Driver Version: 32.0.15.6094
Total Video Memory: 6 GB
C:\Program Files\Gemvision\MatrixGoldRhino8\MatrixGoldRenderPlugin\MatrixGoldRenderPlugin.rhp “MatrixGoldRenderPlugin” 1.0.0.0
C:\Program Files\Gemvision\MatrixGoldRhino8\MatrixGoldPlugin\MatrixGoldPlugin.rhp “MatrixGoldPlugin” 3.10.25171.1001
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.14.24345.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.14.24345.15001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.14.24345.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.14.24345.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.14.24345.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.14.24345.15001
Hi Denise -
Remote Desktop is not supported.
