Glass looks dark in rendered mode
Hi, I just installed Rhino 8, I am experiencing this rhino bug in rendered mode as well despite having the latest version. Any tips? than you
pls run _SystemInfo in Rhino and post back the results.
Here is the result.
Rhino 8 SR11 2024-8-13 (Rhino 8, 8.11.24226.06001, Git hash:master @ bdb34e68e0160956fc5633ba163aeb8fe1301c50)
License type: Educational, build 2024-08-13
License details: Stand-Alone
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 16GB)
.NET 7.0.0
Computer platform: LAPTOP - Plugged in [80% battery remaining]
Primary display: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 6-1-2021 (M-D-Y).
Integrated graphics device with 3 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
Primary OpenGL: NVIDIA Quadro P1000 (NVidia) Memory: 4GB, Driver date: 6-1-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 555.99
Integrated accelerated graphics device (shares primary device ports)
  • Video pass-through to primary display device
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-1-2024
Driver Version: 32.0.15.5599
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Enscape\Enscape.Rhino.Plugin-net48\Enscape.Rhino8.Plugin.dll “Enscape.Rhino8.Plugin” 4.1.0.2321
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros 6\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.11.24226.6001
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.11.24226.6001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.11.24226.6001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.11.24226.6001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.11.24226.6001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.11.24226.6001
@lyra systeminfo seems fine. Can you post a screenshot of what you are seeing, and a file that shows the issue? Thanks.
Good to know. The glass finish that I’m using is showing up as black/gray despite trying multiple things. This material presented normally in rhino 6. This also occurs with any other clear/shiny material that I apply.
Not sure how to send you a file of the issue, do you want me to send you this whole file with my geometry?
I moved this to a new topic, since it is not the same issue as the issue you posted this in.
Glass like materials in rendered mode are far from ideal currently.
There is this YT RH-81590 Glass material is useless in Rendered mode.
Wondering what the solution is? It worked well in Rhino 6, I use glass on all of my projects, so hoping for a way to repair or alternative.
Thank you
Lyra
Hello @lyra
I added a note in that YT
Wondering if you can please clarify, is there nothing I can do to get the glass material working in rendered mode in rhino 8? It works well in Rhino 6, so it’s frustrating, especially since I use glass in every project.
If there is a way to repair or fix this problem can you please let me know.
The RH-81590 link didn’t work.
I have found that it’s very difficult to make glass that is not dark. Yes, even in V8.
Hi Lyra -
I’ve made that issue public.
→ RH-81590 Glass material is useless in Rendered mode.
It doesn’t look like there is a quick fix for this…
Hi @lyra ,
The best solution I can offer you now is to use the Custom material type for glass in the Rendered display mode. Here’s an example…
CustomGlass.3dm (373.1 KB)
Keep in mind, if you also use the Raytraced display mode or Rhino Render, you’ll need to adjust the transparency of that custom material and make the color lighter as shown below.
Thanks so much.
Lyra
RH-81590 is fixed in Rhino WIP
