First set of contours worked out okay, but every supplemental set just does not load. Contouring a simple mesh imported from Google Earth/SketchUp that just does not want to be happy
Pascal, apologies for only seeing this now. Would you still like the file?
Hi Julia - I got your file- thanks. So far here, contours are instant… can you give me an exact blow by blow to make the problem appear?
thanks,
Hi Pascal!
When I was doing it, it worked for the initial contour. But when I tried to do a second set of contours (in another direction), it just didn’t process. I haven’t tried it in the newest version of Rhino/Mac yet.
Hi Julia- ok- let me know if it still bogs down, but here it is fine as far as I can see.
It may have been resolved in the update, but thank you!
