All the changes I make in the settings editor aren’t being applied. The bug seems to affect all values (at least color ones). The command prompt says something like “updating settings” when i OK out of the options dialog, but none of the changes have taken effect and all values have reverted to default if i open options again.
Hi Bert, it seems to work over here using 6.0.14316.5541, 12.11.2014. What version do you have ?
c.
Same one. But 11.12.2014 because 'Murica.
Hi Bert, thats strange. If you run only a single instance of the wip explicitly as admin (right click, then run as admin) does it still misbehave with saving settings ?
c.
Not consistently. Still doing the same thing, but it’s weird because the first time i opened WIP today the command line had changed to the color that i picked before, even though it hadn’t been yesterday. I tried running as admin and changing the color again to no effect. Guess I’ll see if it works next week!
