Hello
Since a few days, the wireframe mode on Rhino 6 looks like shade mode, I have not changed any options.
I have the same options as Rhino 5.
I attached screenshots
Thanks
And, did you try Restaurar valores predeterminados?
yes, I tried it after your first comment.
Setting wire thickness to 1, and having square control points with white center and size 2 works just fine here.
Can you post a screenshot with the model and the Display panel open? Maybe also post the results of the Rhino command _SystemInfo.
With the entire model selected run _SetObjectDisplayMode _Mode=_UseView. Did that help?
no, still the same
I’m out of ideas. @pascal?
Hola @oteroscalemodels - Is this file specific or is this happening with any file?
Hi @Vanessa
With any file on Rhino 6
@oteroscalemodels - Ok, thanks. The one thing you can try while Pascal or one of the devs kick in, is importing the attached Wireframe.ini file. You can do this in the Options > View >Display Mode page > “Import”. This will allow you to replace your Wireframe display mode with this “clean” one (in case yours got somehow corrupted).
Wireframe.ini (11.4 KB)
Thank you so much! it works!
Great
