The sizes of the surface edges in Rhino Beta 6 are much larger then in Rhino 5. And when I pick a line or curve the control points seem to be ON as default. Where do I change these settings?
Control points on:
You can turn that off with these settings:
Rhino Options > Mouse > Selecting > Allow selecting objects with points on
and
Rhino Options > Mouse > Selecting > Turn on control points when selecting a curve, light or annotation
Edge thickness:
I am supposing that you have those set to 1 in the display mode. For the time being, you can use the following test command:
testWireThicknessScale
See this thread:
Thank you. Both suggestions worked great. Control points are now off and the TestWireThicknessScale command did the trick. All I did was turn it on.
Thanks again.
Do note that you’ll have to turn it on every time.
And that the developers would like you to let them know which value you like best.
Will do. For now, Scale=0.5 works just fine.
Thank you.
