Is there way to set series of command as one hot key?
For example, I’d like to dupedge, then join, then remove knots, then subcrv to get a short curve from edge.
When I type a hot key and enter, I’d like to do the dupedge then after that is done, have the join done, then remove the knots, and get the subcrv command to pop-up.
@Toshiaki_Takano, you might try a macro and set it to a button or keyboard shortcut. Note that _SubCurve can only work on a single curve, so _Join must create a single curve or it will fail:
! _DupEdge _Pause _Join _RemoveMultiknot _SubCurve _Pause _Pause _Pause _SelLast
c.
Thanks! will try it out.
