how can i create a new botton with two or more action like “join & close crv”
How to create macros tutorial
How to set up macros/scripts in buttons
In principle the macro should look like this:
! _Join _Pause _SelLast _CloseCrv
However Join is one of those nasty mis-programmed commands for macros, you will need one “_Pause” for each item you intend to pick. So it looks more like this:
! _Join _Pause _Pause _Pause _Pause _Pause _Pause _Pause _Pause _Pause _Pause _Pause _Pause _Pause _Pause _Pause _SelLast _CloseCrv
(use as many pauses as you might want to pick curves, more won’t hurt)
However, an easier way to do this is the following:
! _Select _Pause _Join _SelLast _CloseCrv
–Mitch
Thank you very much
Oljaito
