Display Section attribute hatches at same scale in all detail windows
I believe there’s a setting to have section attribute hatching display at the same scale on a layout even if the sale of detail windows vary. I thought it was a setting in layout properties, but I can’t see it there.
Yes @Djhg, you can manage this with the Toggle Hatch Scaling command (inside the Drafting toolbar):
Thanks Francesc, but I can’t get it to work as I expect. Maybe I’m doing something wrong. When enabled It changes only the most recently active detail window’s display scale (of a sectioned section property hatch) to a heavily reduced scale, but the same object in a different window doesn’t change to match, and different values for the scaling has no effect that I can discern. Rhino 7, VisualArq 2.13.2.17721
HatchScalingNotWorking
Hi @djhg after toggling the hatch scale, you need to click inside one of the detail viewsto display the changes. If this still doesn’t work for you, please share that file so I can better understand what’s happening.
I hope to upload the project. Doesn’t matter if I click in the detail window or not, it still doesn’t seem to work.
