So i want to make a template with one layer called “DIM” and set Dimension layer by “SetDimlayer” command, it is working fine as i am working on file but when i save this as a template it resets to active layer but in template i want to set it always to DIM layer. is there anything i am doing wrong.
hi @Kalpit_3d the command only lives as long as your Rhino session lasts. You could make a macro that is run every time you open Rhino.
