SetDimensionLayer for leaders?
Hi! I just discovered the SetDimensionLayer command and its great, replaces some alises I’ve been using for years. Does anyone know if there’s something similar for leaders, or a way to have leaders go to the same layer?
Thanks!
Hm - no- would you expect leaders to follow dimensions if there were no separate setting?
RH-64977 SetDimensionLayer: Include leaders
yes, i generally keep all my dimensions and leaders etc on one layer
Interesting command, wasn’t aware it exists. Thanks
I use Rhino on Mac & Windows, SetDimensionLayer doesn’t work on the Mac side 🤷
It does seem to work, here, but the input for using an existing layer is a bit awkward, not to say broken, it seems to me. I’ll poke at it some more.
Definitely not working on my Mac, I call the command, set it to current layer, do some dims with another layer active, the dims are not on the dims layer 🤷
Yeah, I think that is the expected behavior - the current layer sets the new dimension object layer - normal behavior for new objects, in other words, is what that means. To specify a layer you need to use the other option.
I think I get it to work now, with specifying layer, its very tricky though, to me if you click set to current layer that should just stick too, 🤷
Hi Pascal,
Would it also be possible to make this command remember the changes after closing and reopening rhino? I generally use the same layer name for all my files.
Hi -
You can put the command and layer name in your start-up commands.
Ah, I did not know about that field. Thanks!
