Set object display mode not working
I have created several display modes, some have been created as edited copies from native display modes (for instance copied arctic to create an arctic xray style), some others i have created from scratch.I use no spaces beetween words in my display modes names.
The problem i have is with the “setobjectdisplaymode” command. When i use it on an object it does not necesseraly change it’s display. For instance, when i m running my display on arctic, and as rhino to display an object as wireframe, or xray, or ghosted, it does not work.
Anyone has this problem too ?
Thank you all !
Hi Raouf -
Please run the Rhino SystemInfo command and copy-paste the result here.
Also, are you seeing this issue with native display modes that were not modified?
Here’s my system info
Rhino 7 SR9 2021-8-10 (Rhino 7, 7.9.21222.15001, Git hash:master @ 190335c3fb65efe86c302714a8959a7dadfe667b)
License type: Commercial, build 2021-08-10
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro M2000 (NVidia) Memory: 4GB, Driver date: 3-10-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 461.92
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-10-2021
Driver Version: 27.21.14.6192
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Users\rdj\Desktop\RAOUF\000_SOFTWARES\ADDONS_RHINO GRASSHOPER\elefront422\elefront421\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Users\rdj\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.21250.810
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros 6\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.9.21222.15001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\RhinoLabsTools.rhp “Rhino Labs Tools”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.9.21222.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.9.21222.15001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.9.21222.15001
C:\Program Files\Rhino 7\Plug-ins\export_PDF.rhp “PDF Export” 7.9.21222.15001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.9.21222.15001
Hello - the first thing to do is update Rhino (help menu > Check for updates) then make sure vray is also updated to the latest. If that does not sort it out, please block VRay, Enscape and elefront in Options > Plug-ins page and then close and re-open Rhino.
I dont think that is the issue.
Sometimes setting objects display modes work.
For instance, running my display on arctic mode and setting and object display mode on a custom mode i created works.
Maybe there’s a way display modes work i’m not aware of. I’m talking about display mode priorities. For instance, if i use a display mode that does not allow mesh wires to show, then set the display of an object on a display mode that shows mesh wireframes will it work ?
I have similar problem, it always display the modes I set to. However I find it works the best when I set the display mode to Pen (or its vairations), then set other objects individually for its own display mode. Hope this helps abit
