SetObjectDisplayMode in 2D plans (Layout) - Bug
Hello!
I have an issue with the SetObjectDisplayMode command in 2D plans.
When I enabled a specific display mode in a detail in the layout and then ran the SetObjectDisplayMode command on individual objects, a display error formed for some objects by displaying them in gray in this case. This spread randomly across the objects. And when I zoom out and zoom back in to another part of the layout, this error occurs on a different object.
At first I thought this was just a display error. However, this is also printed out.
I have attached a short video which demonstrates this quite well. To make it easier to see, I have run SetObjectDisplayMode on each object (Original Display Mode is Arctic).
Cheers
Hi Alexander, Can you type SystemInfo in the Rhino command line and paste the results here please? Thanks.
Hi Japhy,
I tested it on two systems and got the same result. Here are the infos of one of them.
Rhino 7 SR26 2022-12-9 (Rhino 7, 7.26.22343.17001, Git hash:master @ 926b0597fc80bad52906c20e03b0664c6dfde097)
License type: Kommerziell, build 2022-12-09
License details: Cloud Zoo
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display: NVIDIA GeForce GTX 1070 (NVidia) Memory: 8GB, Driver date: 7-21-2022 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 1080 (NVidia) Memory: 8GB, Driver date: 7-21-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 516.94
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-21-2022
Driver Version: 31.0.15.1694
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\OctaneRenderForRhino (f109bd23-4cf3-4c0b-9f83-06be474b0152)\2021.1.0.130\RHI Installer 7\Rhino 7.0\x64\OctaneRenderForRhino.rhp “OctaneRenderForRhino” 2021.1.0.130
C:\ProgramData\McNeel\Rhinoceros\6.0\Plug-ins\Twinmotion Direct Link 2020.2 (e24ee14a-9514-47da-8fe6-f6e61b20160e)\Twinmotion Direct Link 2020.rhp “Twinmotion Direct Link 2020” 1.0.6.0
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 5.0.3.0
C:\Program Files\Doliwa Workshop\Rhino Nature\Rhino Nature.rhp “Rhino Nature” 1.0.2.42286
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Program Files\Bongo 2.0 (64-bit)\Rhino6\Bongo.20.rhp “Bongo 2.0”
C:\Program Files\Mindesk\Rhinoceros\Mindesk.rhp “Mindesk”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.26.22343.17001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Users\Bienek\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\RPC\0.0.12\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\RhinoLabsTools.rhp “Rhino Labs Tools”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.26.22343.17001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.26.22343.17001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.26.22343.17001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.26.22343.17001
I Alexander -
I’m not seeing that behavior here.
Have you tried disabling all 3rd party plug-ins, restarting Rhino with a factory-default template, and creating, e.g., 2 or 3 simple boxes? If you do so, can you still reproduce the issue?
Also, by default, the Arctic display mode doesn’t show any color at all - if you can reproduce the issue with a simple scene as described above, we’d probably also need the custom display mode that you are using.
