Sometimes the SetObjectDisplayMode does not work as intended for me. When running the command, I get the prompt “Choose attributes for selected objects”, but no further settings or input choices (instead of the UseMode thing that I usually get, where I can input M to display a list of the available display styles and being able to choose one.
Does this sound familiar to anyone? What might be causing this? Thanks in advance!
Hi Agnes -
Could you post a screenshot of Rhino when you see this on the command line?
Also, please run the Rhino SystemInfo command and copy-paste the result here.
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: LAPTOP - Plugged in [97% battery remaining]
Primary display and OpenGL: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 11-15-2021 (M-D-Y). OpenGL Ver: 4.6.0 - Build 30.0.101.1122
Secondary graphics devices.
NVIDIA Quadro P2000 (NVidia) Memory: 4GB, Driver date: 10-19-2022 (M-D-Y).
- This device is not being used
ATTENTION:
No graphics device is being used. Either an error occurred on startup, or certain devices have been disabled.
See below for any possible configuration changes that may help resolve this issue.
Any hardware configuration or cabling changes you make will require that you restart Rhino.
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.6
Shading Language: 4.60 - Build 30.0.101.1122
Driver Date: 11-15-2021
Driver Version: 30.0.101.1122
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 5.0.3.0
c:\Program Files\Solemma\ClimateStudio\bin\ClimateStudioRhino.rhp “ClimateStudioRhino” 1.8.8244.25334
C:\Program Files\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.22334.1442
C:\Users\91alu.WHITE\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\ColorPicker\6.0.0\ColorPicker.rhp “ColorPicker”
C:\Users\91alu.WHITE\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SubstanceImporter\2.0.3\Substance.Win.rhp “SubstanceImporter” 2.0.3.0
C:\Users\91alu.WHITE\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Users\91alu.WHITE\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Program Files\Geometry Gym\Rhino3d\BullAnt.rhp “bullant” 1.4.4.0
C:\ProgramData\McNeel\Rhinoceros\packages\7.0\LadybugTools\1.36.157\Ladybug.RH.Loader.rhp “Ladybug.RH.Loader” 1.36.157.0
C:\ProgramData\McNeel\Rhinoceros\packages\7.0\Pollination\1.9.6\Pollination.RH.Loader.rhp “Pollination.RH.Loader” 1.9.6.0
You need to find a way to get Windows to use that NVIDIA GPU in your machine. I’d start by updating the drivers, and, if that doesn’t fix that, go into the NVIDIA control panel to check settings.
Apart from that, you have a lot of 3rd party plug-ins. I’d disable all of those and restart Rhino to see if that makes any difference.
Primary display: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 11-15-2021 (M-D-Y).
Primary OpenGL: NVIDIA Quadro P2000 (NVidia) Memory: 4GB, Driver date: 4-18-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 528.95
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-18-2023
Driver Version: 31.0.15.2895
Total Video Memory: 4 GB
