Set Drawing Plane to Section Plane
Which command sets the drawing plane to the section plane in a detail window.
Is it “align view to section” or “set section view to viewport” or both, or either?
Is it the same in a viewport?
Please verify which of these succeeds in proper use. I’ve received conflicting advice on this in the past.
thanks.
Hi @djhg Both commands do the same, either in the model viewport as in a layout detail view. But the “Set Section View to Viewport” changes the zoom of the view to adjust it to section length, and changes the display mode to Hidden.
Remember that you can check the documentation (vaHelp) for more details.
Thanks Francesc.
