V5
I think I understand Cplanes then something doesnt work again.
default new file, and top I have for top, front for front and right for side view.
Brain likes that, bet I am not the only one.
Construction planes set to Standard.
draw a box 1ft square to set Cplane to so its 1ft higher up.
use Set Cplane 3 point.
1st click the corner of box above 0,0
2nd click the edge of box corner above red axis, 3rd click corner of box above green axis.
doing this in perspective view.
result it moves to where expected, in perspective view, top view and front view, BUT right view hasnt moved.
WHY ?
how can it be 1ft higher in some but not all ?
try working on the model with that conundrum !
the good thing is my top is top, front front and side is still side,
(yes I know its nothing to do with name, but its comfortable this way)
Tractor default cplane test set cplane 3 point doesnt move in lower right pane.3dm (133.4 KB)
I was working on a file and needed Cplane up by 3/4 inch, so drew the block, did all this and in side view it hadnt moved. Try it on tractor and get same failure. Had to end the job as a result.
I just feel like Cplanes hate me. I never ever get what I need from them. I am sure other users would also be baffled.
Steve
