Selecting Sublayer Objects
Hi, is there a way to select all objects on a layer including the objects on all the sublayers like there is in the win version?
If not, is there a plan to implement it in the future? I’m (would be) using this feature all the time, and currently I have to unfold all the sublayers and highlight them all, to then finally be able to select all objects of the layer.
The feature would be a huge time saver…
Thanks.
-Daniel
Thanks for the report, I filed https://mcneel.myjetbrains.com/youtrack/issue/RH-44106 for future reference so this gets added. In the meantime, I found the fastest workaround is to use SelLayer and then left click and drag over the sub layers.
Hi Brian, thanks for the quick reply,
the SelLayer workaround is good to know!
Looking forward to when the feature is implemented though! :wink:
