Does Rhino have a tool to select self intersecting surfaces or polysurfaces like these?
If not is it possible to find them in Grasshopper?
self int.3dm (784.5 KB)
One “trick” is to create a mesh from the surface, then determine of the mesh self-intersects.
Rikkarlo.gh (33.3 KB)
– Dale
The closest thing (I think) to do so manually in Rhino would be to:
SelMesh
MeshSelfIntersect
, hit ESC buttonSelCrv
to hightlight all curves resulting from mesh self intersections to visually confirm which meshes had self-intersectionsHowever to really streamline this process Dale’s C# option in grasshopper is the way to go.
Thank you very much!
I’ll try to ask chat GPT if it can help me write the script and I’ll let you know if I succeed!
I’ve noticed that the mesh self intersect command works for surfaces and poly-surfaces as well (I guess it makes the mesh by itself and erase it afterwards), but does not always succeed into finding self intersections of poly surfaces
