Self intersecting surfaces
How to check a surface for self-intersection. Also, then identifying the intersection for a probable fix to the geometry…?
Thanks in advance!!
Hello- setting a display mode to show colored back faces is one way to locate these:
I would use Mesh command to convert the surface to a mesh and then I would use MeshSelfIntersect command to find the self-intersections.
IntersectSelfSrf is somethig that I also need, and a few others in other topics.
Any chance for it in Rhino 8?
Kind regards.
