Select QuadMesh
Is there a way to distinguish between quad and tri meshes? Thanks
Hi Hannes most meshes are likely to be a mix, there is no built in tool for that - here’s a python that will select all-quad meshes:
import Rhino
def SelQuadMesh():
    ids = rs.ObjectsByType(32,False, 1)
    if not ids: return
    geos = [rs.coercemesh(id) for id in ids]
    for i in range(len(geos)):
        sel= True
        for face in geos[i].Faces:
            if face.IsTriangle:
                sel= False
                break
        if sel:
            rs.SelectObject(ids[i])
if __name__ == "__main__":
    SelQuadMesh()
triangle only ones
import Rhino
def SelTriMesh():
    if not ids: return
        sel= True
            if not face.IsTriangle:
                sel= False
                break
        if sel:
    SelTriMesh()
or mixed ones
import Rhino
def SelMixedMesh():
    if not ids: return
        tri = 0
        quad = 0
            if face.IsTriangle:
                tri= 1
            else:
                quad = 1
            if tri + quad == 2:
                break
    SelMixedMesh()
Thank you @pascal
