Hi guys, if I coerce a mesh and print the face info I get a list of the vertices, but I can not len(face) to see if they are 3 or 4 vertices. And if i print them then they show up with either t or q as a preface:
So I presume there is a fast way to tell if it is a triangle or a quad, but I can not figure out how…
Anybody knows?
Oh…
if face.IsQuad:
does the trick!
IIRC triangles have the last two indices the same, meaning you have four vertices for both quads and tris, so check the third and fourth
Thanks I tried that, but apparently it is different now, see image above.
But I can use
if face.IsQuad == True:
IsQuad indeed is probably the better way. Other than that you could do:
if face.C != face.D: #quad
See
https://developer.rhino3d.com/api/RhinoCommon/html/T_Rhino_Geometry_MeshFace.htm
Thanks as always Nathan!
