Hello, I’m trying to select the curves or edges from a solid body but I dont know how. Or is there a way to do a parallel curve from an edge of the solid? like from a cube? it doesnt make that much sense for a cube but only for visualising my problem/question
thats something which you might encounter pretty often, that on mac things work with cmd rather than with ctrl, just that you know. ctrl is also still the right click of mac. thats why this window popped up.
If there are no underlying curves you need to extract them. Try extractisocurve command to extract a curve on the edge. It is not the most straightforward one but it is a workaround.
I am not sure if there is an extract edge option. Didn’t find it on the mac at least.
