Select-CTRL/Shift Sub Select?
When using the ‘Select’ command, its not possible to sub-select faces/edges etc, is this by design or a bug ? It would be great to also sub-select when activating the Select command :upside_down_face:
In my opinion, SelectionFilterToggle command (F5 shortcut) solves this somewhat imaginary problem.
@andrew.nowicki yeh that works, never crossed my mind to use this, thanks for the tip :+1:t4:. Would still be nice to have the ability to sub select once inside the basic Select command, anyways, that works for me, cheers
