Hi all
Wonder if possible to create shortcut instead of clicking the tiny box to select SbObjects selection filter.
Very usefull tool to me, would appreciate to be more handy
Cheers
Hi all
Cheers
Hi @Petrol
If you run the dashed version -SelectionFilter you get to use the command line to turn on/off the various filters, so you can write your own macro
HTH, Jakob
Hi
Didn’t even think about…
I’ll get a try
Thx
you can use Ctrl Shift click to selec either faces or edges of an object, is that what you want?
Hooo nice ! didn’t know this trick !
Perfect !
I made this macro in Rhino8 and it works as sub-object toggle, also during a command:
NoEcho '-SelectionFilter _subobjects _toggle _enter
Best,
Wow! Thank you so much! Works fast and nice
