An errant command has inverted selection methods.
When I click to select rhino does a shift-ctrl select.
When I shift-ctrl select rhino does an ordinary select.
Would like to get this back to normal.
Hello- check the selection filter - you most likely have ‘sub-objects’ set.
Thanks. That was it. Is there a key command which does this also? It seems I am hitting it accidentally from time to time.
the F5 key is looping from no subobject selection to points, edges, surfaces and back
I see! Thanks. This boils down to a left index finger injury recovery. (Hitting F5 instead of 6)
