Segmented edge display 9 is unclear
9. I can’t see the segmented edges clearly when selecting
Hi @xkdsofa ,
I’m not able to reproduce this issue in the v9 WIP and think it may be specific to a custom display mode you have set up. Does this happen in default Shaded for you too?
I may not be understanding you clearly as well as I can’t figure out what the arrow from the naked edge is indicating in your images.
125
8 selected with highlighted yellow feedback, 9 selected with unclear highlighted display
Is it the same for you in all display modes? How about a default display mode like Shaded? I cannot reproduce the issue here so far. What are the results of your SystemInfo command? Can you share the display mode you are using?
This check has affected the display
