I am trying to take this surface that has been sectioned in grasshopper to have all of its ends meet at the same location similar to the model in the picture I have provided. I have attached the sectioning script that I am working with.
It’s stacked because i gave it some thickness. Do you mean you want only surfaces with no thickness? It’s actually a different problem, as far as I’m concerned.
I’m confused. Since everything was internalized, is it the GH file you want, and for the flat example? Can you upload the code you’re using, or a screenshot?
