Section not working correctly in rhino 8
Rhino 8 bug. The section tool ( _section) is not working correctly when sectioning a mesh. It pumps out multiple garbage lines that are not true sections of the mesh. Sometimes the lines will randomly follow the border of a polygon.
This is observed on a clean closed shrink wrap mesh.
I’ve also noticed the usual command line option of outputting closed lines is not present.
Please fix, thank you.
-Robert
hi Robert, can you send that file? and the result of _Systeminfo?
I cannot repeat that behavior you are seeing here.
Sure, here you go.
Google drive linking the file as I have a string of tests in here showing the bug progress as the poly count goes up, so file is big. The poly count of the extracted sphere is for the original whole sphere of course.
Also the command line option to group or not is affecting the output, which is not normal behavior either.
As mentioned earlier please bring back the ‘joincurves by section plane’ option for _section.
side note, _project is not broken so that will be my workaround for now.
Rhino 8 SR1 2023-11-21 (Rhino 8, 8.1.23325.13001, Git hash:master @ 8a4a437248efac5d9cb04d3904481b83e4c23a64)
License type: Commercial, build 2023-11-21
License details: Cloud Zoo
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 1.9e+02Gb)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA RTX A4000 (NVidia) Memory: 16GB, Driver date: 7-2-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 462.96
Secondary graphics devices.
Intel(R) UHD Graphics 770 (Intel) Memory: 1GB, Driver date: 7-24-2023 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-2-2021
Driver Version: 27.21.14.6296
Z-Buffer depth: 24 bits
Total Video Memory: 16376 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.1.23325.13001
thanks for the sample, I can repeat that here.
RH-78758 Section is not working as expected
As for the missing option:
RH-78757 Section: missing JoinCurves option
thank you!
(damn why my NVDIA driver so old? fixing that now…)
