Rhino 8 Clipping Sections Bug
1.When moving geometry the clipping section deactivates temporarily as seen in attached GIF:
1-31-2024 (15-14-38)
2.While clipping section in active, selected faces or edges of geometry that is not sectioned are not highlighted:
1-31-2024 (15-16-28)
3.Shading issue: when trimming multiple surfaces, if I press ESC shading reverts to wireframe:
SwitchShading-ezgif.com-video-to-gif-converter
Hi Dan,
Can you post your systemInfo? Thanks
Sure:
Rhino 8 SR3 2024-1-9 (Rhino 8, 8.3.24009.15001, Git hash:master @ 3541fa287a013b0f17849f0740f1e43a44031bfc)
License type: Commercial, build 2024-01-09
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32Gb)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce GTX 1080 (NVidia) Memory: 8GB, Driver date: 1-18-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.23
OpenGL Settings
Safe mode: Off
Anti-alias mode: 2x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-18-2024
Driver Version: 31.0.15.5123
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.3.24009.15001
Thanks i was able to repeat the first two, but not the last. I’ll get the two youtracks (bug reports) going an circle back to the third.
testing in 8.5.24031.02001
Item 1: RH-80127
Item 2: RH-80128
Not able to replicate this one, perhaps someone else can.
If not I may need more step by step instructions to reproduce along with the file. Thanks
Thanks for the replies . I’ll set up a file and step by step instructions. Maybe it has something with my hardware performance?
Steps:
  1. go to perspective view (shaded)
  2. select cutting plane (green)
  3. Enter trim in command line
  4. Click on the object to be cut (red surfaces)
  5. Hit ESCAPE
    After this the viewport should revert to wireframe (at least it does in my case)
Shadding_issue_01.3dm (62.2 KB)
Still not able to repeat and your graphics setups looks OK. Lets get you on the latest service release and see if this was something previously fixed.
The latest Service Release Candidate is 8.4
Go to File>Properties>Updates
Thank you. That solved it.
