Hi
I can’t find settings that makes the side Panels, Wacom Pen scrollable?
Is there a way to do that ? and if not can this be please added?
Thanks a lot
Akash
Hi
Thanks a lot
Akash
It looks like it’s possible if you set one of the buttons on the stylus to “Scroll” and then click and drag in the panel. Set this in the OSX system preferences for Wacom > the button > Navigation > Scroll. The touch ring also works if you have one of those on your tablet.
Thank you
Yes, I set one button to scroll function. I’ll try to see if I can get use to it. [it’s the different pen behaviour between apps that make’s it tricky]
I set the touch wheel for fast swap between view port.
there’s an issue there… I’ll open a new thread for it.
thanks a lot
Akash
Hi @Akash
If you do not use Middle Mouse Button as me, you can set up as below:
Hi Thanks
Actually the post was about Scrolling not zooming.
I’m well aware of the pen buttons option, only that agronomical they are not all that comfortable.
I do use the pen for zooming but only In Zbrush [ pen buttons are not needed in that app]
In Rhino [and in Fusion] a 3DConnexion device is much better for navigation + zooming
Akash
