Advocir
October 28, 2020, 1:34am
#1
Tenho um projeto com varias peças e quero exportar cada uma delas em dxf separadamente de uma unica vez , é possivel? me ajudem!
gustojunk
(Gustavo Fontana)
October 28, 2020, 1:52am
#2
a couple of options here:
I’m using the nest feature of RhinoCam, it let’s me export 60 sheets of nested parts to files but only to .3DM which will mean nothing to the laser cutter operator. I contacted MecSoft and they suggested contacting McNeel, thought I’d try here first.
"You can check with McNeel support to see if they could come up with some sort of a script that can take the 3dm files and convert it to dxf’s without having to convert each file manually.
Alternatively you can check if they can help you with a sc…
Advocir
October 28, 2020, 1:57am
#3
Obrigado pela resposta! mas ainda preciso separar por layer cada um dos arquivos, como eu poderia melhorar isso?
Advocir
October 28, 2020, 12:49pm
#5
gankeyu, muito útil, mas não para a minha aplicação, eu tenho varios desenhos geometricos e quero automatizar a exportação em dxf, pois trabalho com grandes quantidades de arquivos.
gankeyu
(Keyu Gan)
October 28, 2020, 1:27pm
#6
If you may, you can upload some of your files so that others can figure out what is the best way to achieve your goal.
