Is there any way for me to scale my floor plans, section and elevation all drawn at 1:1 scale in millimetres to 1:50 scale in m?
Thank you!
Thank you!
Hello - use a Layout
, then you can scale the detail views there as needed - does that do what you need?
I don’t think it does, initially I wanted to use Illustrator to scale my drawings, but even after relocating my drawing near the origin point, it still did not show up in Illustrator, do you have any other recommendations as to how I can change the scale of my drawing? Thanks!
Ah, OK, if you print to PDF from the layout you can set the scale of the print. But if you really need to scale the model, select all and
! Scale 0 1/50
Export, then Undo.
