Hello) After years of experiments to make architectural rendering professionally, I found some problems rhino
or, the rhino is very bad for the architectural rendering, and the reasons are:
About exporting (obj) from the max to the furniture, for example, the furniture will be very large, and the reason is not the max scale, but the problem in scale of rhino !
As if the real problem is the scale useing in rhino. If you used the scale of the imported furniture from the max to rhino and do everything big to match with the scale of the furniture, the results will be amazing and vice versa.
Therefore, I ask you to pay attention and scrutiny in my words because I wrote it is the result of years of experiences
I will attach photos that were made using V_ray but without rescale the max file
And when rescale, the results will be miserable
