There is an inconsistency with _SaveSmall compared to using _Save or _SaveAs. It defaults to SaveTextures=No where the others default to SaveTextures=Yes.
_SaveSmall also doesn’t present an option for SaveTextures, nor does -SaveSmall present any command line options if the file already has a name.
Here are some sample output files with a picture frame in them
-Save SaveSmall=Yes
-SaveAs SaveSmall=Yes
_SaveSmall
Clipboard-Save-Small.3dm (197.5 KB)
Clipboard-SaveAs-Small.3dm (198.8 KB)
Clipboard-SaveSmall.3dm (71.6 KB)
Here is the relevant sections from _Audit3dmFile:
Save or SaveAs with SaveSmall=Yes:
Embedded image Table:
0 embedded images, 24 bytes (offset 35528 to 35552)
Texture Mapping Table:
0 texture mappings, 24 bytes (offset 35552 to 35576)
Legacy Material Table:
material[0]: Clipboard-3d14cd80-2606-4186-a752-a5ffdfe6496b
1 materials, 1702 bytes (offset 35576 to 37278)
Render Materials:
1 materials, 9001 bytes
Embedded Files:
embedded file[0]: C:\Users\EricM\AppData\Local\McNeel\Rhinoceros\8.0\PastedImages\Clipboard-3d14cd80-2606-4186-a752-a5ffdfe6496b.png, 130302 bytes
1 embedded files, 130302 bytes
SaveSmall:
0 embedded images, 24 bytes (offset 37133 to 37157)
0 texture mappings, 24 bytes (offset 37157 to 37181)
1 materials, 1702 bytes (offset 37181 to 38883)
Render Materials:
Embedded Files:
0 embedded files, 0 bytes
