Save Small - Do you want to Save
(Sorry if i can not give a robust workflow to reproduce.)
I love to keep .3dm files small, for example when posting here in the forum.
Using File → (alt) Save As (and check “Save Small”)
or
File → Save Small
Now wanting to close the document.
without any changes many times I get a
Do you want to save changes… Pop up.
Save - it will override the Save Small Version
Cancel - the document is not closed
Revert Changes - completely unclear to which version.
(in fact Revert Changes will do what i want: keep the Save Small Version, so not doing a Revert…)
main wish
Please make the dialog more clear best add a Version / Timestam Info:
(Revert to Version saved at … Date / Time )
pressing cancel after a while I get:
maybe those issues are related:
Thanks
I know its weird but the solution is…
FILE → SAVE than FILE —>SAVESMALL
Rg,
thanks for your answer.
would call it work around :grin:
i would love at least to have a info Revert below or above - version, time, date
You’re not on an M1 are you? Can you send me your systeminfo?
Macbook Pro 2019, Intel.
Version 7 (7.25.22321.17002, 2022-11-17)
Local save for rhino, no cloud
systeminfo_tom_p_2022-22.txt (3.5 KB)
thanks, I have something similar, will try to reproduce
edit: @Tom_P looks like I know how to reproduce:
Open a file
make an edit and undo (Document still stays Edited)
SaveSmall
result:
Document Edit state doesn’t change
After a few seconds this will make the popup appear as you mentioned.
Does this match with what you’re seeing?
logged as RH-71606 SaveSmall doesn’t update document edited status
