I have Rhino 7 SR26 (7.26.23009.7001) Educational License. I run into an issue whenever I try to save a named view, Rhino freezes and nothing appears in the command bar. If I click ESC, everything is fine and Rhino will become normal. But I’m unable to save any named view.
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: LAPTOP - Plugged in [97% battery remaining]
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 1-10-2022 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 3080 Ti Laptop GPU (NVidia) Memory: 16GB, Driver date: 8-2-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 517.00
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-2-2022
Driver Version: 31.0.15.1700
Z-Buffer depth: 24 bits
Total Video Memory: 16 GB
C:\Users\Finn RHok\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.22258.1121
C:\Users\Finn RHok\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\D5Conv (e0d5e210-02f6-4ee9-a2b0-1675e225d958)\0.10.1.0001\Rhino 7\D5Conv.rhp “D5Converter for Rhino”
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
Hello- please try this, maybe we can pin this on a plug-in. - in Options > PlugIns page, disable Vray, Enscape and D5Converter.
Close and re-open Rhino.
Does the problem go away? If so, re-enable those plug-ins one at a time until you see the problem again…
Hello - Thank you so much. It works. I followed your instruction, then closed and re-opened Rhino. After that, I checked back those PlugIns then closed and re-opened Rhino again. Everything works fine now. I appreciate your help
