Every time I tried to save a named view, rhino crashes. I see there is a similar thread from 2018 running rhino 6, but I’m running Rhino 7 on Windows 10, looking for a solution.
Thanks.
Thanks.
In every file or just a specific file?
If it’s the first, run _Systeminfo and post the results back here.
If it’s the latter, these would be the first things I’d try:
See if there are any bad objects in your file (_SelBadObjects) and remove or repair them.
Make a new file and import your file into the new file and see if the problem persists.
It’s hard to say, there doesn’t appear to be any rhyme or reason. If i open a new blank file, it’s fine. Same if I open an old rhino 6 file. I don’t know if I have many rhino 7 files but the two most recent that I’ve been working on, having nothing at all to do with one another, crash when I try to save a named view. I tried as you advised, but there was no bad geometry.
Hello- please run the SystemInfo command in Rhino and copy/paste the results here.
Rhino 7 SR13 2021-12-7 (Rhino 7, 7.13.21341.05411, Git hash:master @ 45edb3f0b4f8cd1af41e883b112aea508d01118e)
License type: Commercial, build 2021-12-07
License details: Stand-Alone
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 1.3e+02Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2080 Ti (NVidia) Memory: 11GB, Driver date: 10-26-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 472.47
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-26-2021
Driver Version: 30.0.14.7247
Z-Buffer depth: 24 bits
Total Video Memory: 11 GB
C:\Program Files\Geometry Gym\Rhino3d\BullAnt.rhp “bullant” 1.4.4.0
C:\Users\bdb\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\KeyShot10RhinoPlugin (ccedd9da-83b9-429a-aec5-8ec90b85fe67)\1.2.0.0\KeyShot10RhinoPlugin\Rhino 7\KeyShot10RhinoPlugin.rhp “KeyShot10RhinoPlugin” 1.2.0.0
C:\Users\bdb\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\TeDAsharp (ce983e9d-72de-4a79-8832-7c374e6e26de)\1.0.6981.15425\TeDaSharp.rhp “TeDAsharp” 1.0.6981.15425
C:\Program Files (x86)\Evolute\EvoluteTools LITE for Rhino 6\EvoluteCoutHook.rhp “EvoluteCoutHook”
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.13.21341.5411
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.13.21341.5411
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.13.21341.5411
C:\Users\bdb\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2020.12.9.865\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.13.21341.5411
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.13.21341.5411
Disable third-party plug-ins and see if it still happens.
i’ll give it a try, but that’s really not a solution seeing as how i need those plug-ins.
thanks.
You’re not looking for solutions yet.
You’re trying to identify the problem.
Once identified, then we move towards a solution.
