Is there a way to save layer properties as template from rhino and use it later, just as I can save materials?
For example, if I have a layer for steel beams, it has its basic properties materials, display color, plot color, lineweight, linetype and all. If I make a layer of steel beam next time in a new file, I would like to use that template and just assign all the layer properties at once instead of setting them each again.
Yes, so that is the way to save the whole rhino file setup as a template with all the sample layer I need and then duplicate them as needed.
But there is no way I can save individual layer properties like all these as some kind sort of file. So next time I make a layer of steel beams, I can just assign all of them once instead of making a duplicate layer and all the elements in that.
Like for example I can save individual materials as “.rtml” files.
