Export just layer name and property
Hello guys, do you know how to export all layers without anything inside from an existing file with all propoerties to be able to import it in an other file ?
Thank you so much
Save the file under a new name, delete the geometry, then save as a template, then when creating a new file, select this template, all layers with settings will be in the new file.
