Hello, (Rhhino 6, 64bit, windwos7)
When you have A open, and Save As to B, the file name shown on top of the window changes to B, that’s the normal behavior I guess.
When I do Save As with Save Small option checked and Save plugin data unchecked, the file name stays as A. I didn’t check any other combination but if you have Save small unckecked and Save plugin data checked (i.e., default settings), the file name changes to B.
I think this is a bug?
Thank you.
