Save Analysis value in clipboard for other use
I have a lot of curves whose length I want to retrieve for use in Excel.
How can I copy a length obtained by Length command to the clipboard??
Thanks
If you export as object properties, you can export the length of curves as .csv and import to a spreadsheet.
Or, you can use length command, click on your objects and then highlight the result on the command line and copy.
