Is it on my end? Thank you
I can get select curve in command line , but no result
On a side note. Say a person has selected some objects and realized that selection was out of sequence. Could or is there a hold selection, while starting a new command? Especially for splitting . Thank you
Hi Mark - Anlayze is a menu in Rhino- what is the actual command in there that you are working with?
Yeah, it just dawned on me I didn’t say analyze length
Length reports the results to the commands line- - it can happen, if the command area is only one line deep, that it scrolls past . Try dragging the lower edge of the command area down a little to get two or three lines of history.
Thanks,and I do remember messing with that yesturday.
