For example; there is a line or curve. i measured its length with length command in rhino 6. How can use its results with macroeditor?
You can copy text and numbers directly out of the command line or command history (F2) with Windows copy and paste…
Hello - in case it helps, Length, Distance and Radius are nestable commands that can be used inside another command to set a number in that command - for example making a circle that has the same radius as an existing circle, without first getting the radius and writing it down or copying to the clipboard.
Whoa… no idea that would work… learn something every day… ![]()
