RuntimeError: CPU dispatcher tracer already initialized
Traceback (most recent call last):
  File "rhinocode:///grasshopper/1/68254ed6-a8aa-4c24-81aa-996a45fa29e6/72178cd4-4eea-44d3-bb37-5c15c2ae2232", line 1, in <module>
  File "C:\Users\tallu\.rhinocode\py39-rh8\site-envs\default-7oeVr66U\numpy\__init__.py", line 143, in <module>
    from numpy.__config__ import show as show_config
  File "C:\Users\tallu\.rhinocode\py39-rh8\site-envs\default-7oeVr66U\numpy\__config__.py", line 4, in <module>
    from numpy._core._multiarray_umath import (
  File "C:\Users\tallu\.rhinocode\py39-rh8\site-envs\default-7oeVr66U\numpy\_core\__init__.py", line 23, in <module>
    from . import multiarray
  File "C:\Users\tallu\.rhinocode\py39-rh8\site-envs\default-7oeVr66U\numpy\_core\multiarray.py", line 10, in <module>
    from . import overrides
  File "C:\Users\tallu\.rhinocode\py39-rh8\site-envs\default-7oeVr66U\numpy\_core\overrides.py", line 8, in <module>
RuntimeError: CPU dispatcher tracer already initlized
I face this issue in Rhino 8. has anyone faced the same. if yes, how did you resolve this?
Which Rhino version?
I had a same issue in Rhino 8 /grasshopper when I import pandas
In my case it was not occurred before I install few Grasshopper Plugins (LadyBug, Butterfly)
I will report here if I solve this problem.
@Namdev
I solved my case, but I’m not sure it will work for you.
In my case, after I reset my labtop. I didn’t add Rhino env directory to in my Environmental Variables.
I think that’s why it occurs crash, because If we don’t add Rhino env directory, python in Rhino look for packages from other directory(which is already using numpy or multiarray in some reason).
You should find your Rhino python Script folder and add it to Environment Variables like this
C:\Users\USERNAME.rhinocode\py39-rh8\Scripts
I hope this will work for you.
I had the same error and it was fixed by updating Rhino.
I wanted to share in case others have the same issue - Check your version and make sure its not old. I was on a version from January 2024, and for some reason Rhino said it was ‘up to date’ so I thought I was good, but in fact i wasn’t :slight_smile:
Rhino 8: after line 2 : import numpy as np
One of our customers also faces this issue when using multiple Python components importing numpy. Interestingly, this doesn’t always happen, and so far it has only happened when running the model on our servers. Any hints would be appreciated.
